BMW Tech and Performance
Engine Tech
E46 M43 Engine Overheated
<blockquote data-quote="tenno" data-source="post: 14290" data-attributes="member: 15290"><p>Hello guys. Im seeking any opinion from u all. I just experienced engine overheated. D engine cant be started due to low compression i think. I have found that my cooler tank was empty. After filled up w water, found that tank was leaking. the scenario is like this...i have observed the temp indicator indicate overheated. smell something burnt out. Shuted down the engine. After few hours start back. Manage to do it. Drive to specialist. On the way for just about 5km i thought, suddently the engine going underpower and and die. Cant be started again. My Q are ..is it enough to top o/houl or transplant the engine? Im wonder if top o/houl carried out, mess could be around esp. w the crankshaft. is it correct?</p></blockquote><p></p>
[QUOTE="tenno, post: 14290, member: 15290"] Hello guys. Im seeking any opinion from u all. I just experienced engine overheated. D engine cant be started due to low compression i think. I have found that my cooler tank was empty. After filled up w water, found that tank was leaking. the scenario is like this...i have observed the temp indicator indicate overheated. smell something burnt out. Shuted down the engine. After few hours start back. Manage to do it. Drive to specialist. On the way for just about 5km i thought, suddently the engine going underpower and and die. Cant be started again. My Q are ..is it enough to top o/houl or transplant the engine? Im wonder if top o/houl carried out, mess could be around esp. w the crankshaft. is it correct? [/QUOTE]
Engine Tech
