e46 Coupe & Sedan
3CI
Dear Si Fu,Just want to know is there any different for the e46 coupe & sedan ?Beside there is 2 door & 4 door ..Regards,3CI
almost all, if not all, the body panels differ between the coupe and sedan
the coupe is also slightly longer, wider and stock suspension setup is marginally lower than the sedan
tail lights and headlamps and indicator lights and bootlid reverse lights are also different
even wing mirrors are not the same
sedan boot spoilers will not fit a coupe bootlid
drivers and front passenger seats are different
all interior panel trim is different
bumpers are probably diffferent too
i c.. thanks for your information :lol:
i tok some different for the engine or gearbox..
regards
No la... Just FYI only la, hehehehehe
engine should be the same
It depends. I think the coupe is slightly heavier even without the 2 extra doors. Further, CIs are usually CBU or UK-specced with more stringent emission safeguards which means slightly lower bhp i.e. 189 bhp for 325Ci vs. CKD 325i's 192 bhp. It's only very slight but the CKD 325i might pip a nose against a Euro 325Ci in a drag.
i c.. so mean all the CBU model must better then the CKD right ?
some spec sheets
318Ci
110/150/6200 kW/hp/rpm
200/148/3600 Nm/lb-ft/rpm
325Ci
141/192/6000 kW/hp/rpm
245/181/3500 Nm/lb-ft/rpm
328Ci
193/5500 hp/rpm
280/206/3500 Nm/lb-ft/rpm
330Ci
170/231/5900 kW/hp/rpm
300/221//3500 Nm/lb-ft/rpm
Have to keep in mind the torque as well. Not just the BHP!
Originally posted by scin@May 9 2006, 12:11 AM
some spec sheets
318Ci
325Ci
328Ci
193/5500 hp/rpm
330Ci
thanks SCIN for all the spec..
Sometimes we consider the recondition car only know their cc , totally doono the spec detail.. difficult :)
thanks for your advice :p
