JKP;569878 said:Am not sure if it can fit E60, but I know the 530 disc rotors are bigger than 523 & 525
The above disc will fit E39 - 523,525 and 528 standard size, if not mistaken it could be 14" in diameter.
hakim_radzuan;569858 said:can be fit to e60?
mizhan;570099 said:are these the same size discs as E46 330i?
JKP;570092 said:E60 disc rotor available but larger ones only, diameter - 324mm
Price RM.990 a pair
The above E39 disc rotor diameter is 296mm
dominic;570130 said:E39 530i rotor disc is 324mm with bigger caliper than E39 529.
just plug and play ya.
bmw7833;570202 said:Plug and play for 523i?
How good if compare with original disc?
bmw7833;570227 said:So where to get the compound brake pad? Any lobang for good price?
bmw7833;570271 said:I know the standard one but since u said the Zimmermann is best to pair with hard compaound pad, right?
