Hi Sifus,Just found my engine temp rising the other day and mech advised my coolant water is somehow seeping into the engine (he found moisture in engine oil cap so likely there is a crack in the engine....).So now need to top up water full every 2 days...Thinking to convert to M50B28 now (no point to stroke up as engine has crack..).If my e36 is M50B20 single vanos, is it true I only need to swap:1) Engine to M50B282) Ecu for M50B283) Rear Axle meant for the M50B28Long shaft no need to change coz chasis still the same?Wire harness use back the existing coz already single vanos?Anything i missed?Lastly, to buy item 1 to 3 + extras in used gd condition, can advise how much for each?Thks in advance
