3 Series
E36
E36 electrical problem, advice needed !!
<blockquote data-quote="Ubi Wan" data-source="post: 25991" data-attributes="member: 23606"><p>Dear sifus,Been enjoying my E36 318i 97 for the past month or so. So far managed to get the glove box replaced and center armrest installedr which has spruced up the interior and making for a more enjoyable drive.Have noticed that while driving when i indicate left the speedometer and RPM drop slightly with no effect on performance, also occasionally when driving all the warning lights on the dash light up and the speedometer ,RPM, fuel and temperature gauge drop to zero for about 3-4 seconds then come back to normal again with no change in performance.So far have changed the indicator/wiper stalk but problem still persists. Thinking of replacing the whole speedometer unit but not sure if that will cure the problem. Any advice?Also the left indicator recently iammed in the on position but that was caused by the indicator relay that was cured with some sanding of the contacts.</p></blockquote><p></p>
[QUOTE="Ubi Wan, post: 25991, member: 23606"] Dear sifus,Been enjoying my E36 318i 97 for the past month or so. So far managed to get the glove box replaced and center armrest installedr which has spruced up the interior and making for a more enjoyable drive.Have noticed that while driving when i indicate left the speedometer and RPM drop slightly with no effect on performance, also occasionally when driving all the warning lights on the dash light up and the speedometer ,RPM, fuel and temperature gauge drop to zero for about 3-4 seconds then come back to normal again with no change in performance.So far have changed the indicator/wiper stalk but problem still persists. Thinking of replacing the whole speedometer unit but not sure if that will cure the problem. Any advice?Also the left indicator recently iammed in the on position but that was caused by the indicator relay that was cured with some sanding of the contacts. [/QUOTE]
3 Series
E36
