E36 Changing to E38 brake disk and caliper
CK1
hi there,I am currently having a E36 328 original brake and intended to change to E38 740 model. I heard before about someone install it before but havent see yet. Anyone ,have any idea whether can be use it or not. I just want to double check before making a wrong decision. Thank you eveyone.
you just need to do the custom brackets to fit them. there are e36's running on porsche calipers. some are skeptical on this mod as it can cause serious mishaps if works not done properly.
caliper can, if your rim can clear it. brake disc can't, hub sitting cannot...bigger
