bolt on turbo to his m42 engine...Originally posted by tombstone@Jul 2 2006, 01:46 PM
may i know how he did the turbo?
bolt on turbo? what turbine?
i witnessed an m20 2.5 vs a m42 turbo lah...Originally posted by DanPromote@Jul 3 2006, 10:59 PM
I'm also interested! If not mistaken it costs roughly about 5k including piggyback ecu like SMT6. Can recommend any good workshops for this?
Tyke has tested a drag race with a 2.5 litre n/a and a 1.8 litre turbo ... u guys can ask him what he thinks.
... Guess its puny... tats why lar... but at least now can race with Wira 1.6..Originally posted by ALBundy@Jul 4 2006, 02:43 PM
The turbo that comes with the kit is puny, probably run out of breath pretty fast if you boost it higher You would probably need a piggyback too!! But I heard your turbo can outrun an e36 325 wor!
Originally posted by E36Turbo+Jul 4 2006, 07:33 AM-->QUOTE (E36Turbo @ Jul 4 2006, 07:33 AM)
kindly elaborate please.. the ford pick-up is 8 valve diesel and lot's of torque.. :blink:Originally posted by BlueMixWhite@Jul 4 2006, 04:11 PM
Guys,
Which engine are you guys talking about....? E36 318 normally in Malaysia is using the M43 engine which is 8 valve and SOHC not suitable for force induction. Whereas the M42 engine with 16 valve and DOHC more suitable. Correct me if i am wrong.
Originally posted by ALBundy+Jul 4 2006, 03:36 PM-->QUOTE (ALBundy @ Jul 4 2006, 03:36 PM)Originally posted by E36Turbo@Jul 4 2006, 07:33 AM
YOU are rite .... :yes: ....Originally posted by ALBundy@Jul 4 2006, 04:45 PM
Both engines are suitable for forced induction, since there are knock sensors. Of course the M42 is the prime candidate with its stronger internals (forged crank, conrods), sodium coated valves, DOHC and etc.
But then again, with the high compression ratio, its only safe to run low boost level ~~ 0.5-0.6 bar.
Alternatively, if you have USD 3395 to splash, Downing Atlanta does make a supercharger kit for the 318 using similar Eaton compressor unit as those found in the Mercedes. More than 210hp at the crank!
Originally posted by E36Turbo+Jul 4 2006, 08:46 AM-->QUOTE (E36Turbo @ Jul 4 2006, 08:46 AM)Originally posted by ALBundy@Jul 4 2006, 03:36 PM
Originally posted by ALBundy+Jul 4 2006, 04:55 PM-->QUOTE (ALBundy @ Jul 4 2006, 04:55 PM)Originally posted by E36Turbo@Jul 4 2006, 08:46 AM
