5 Series
e34 vibration while stationary in D
<blockquote data-quote="CAJ19" data-source="post: 37829" data-attributes="member: 105"><p>the throttle flap in the throttle body is sticky, maybe. Remove the air inlet hose to throttle body and spray some carb. cleaner into the flap spindle,( top and bottom) . Check the throttle linkage for worn-out ball joints.</p></blockquote><p></p>
[QUOTE="CAJ19, post: 37829, member: 105"] the throttle flap in the throttle body is sticky, maybe. Remove the air inlet hose to throttle body and spray some carb. cleaner into the flap spindle,( top and bottom) . Check the throttle linkage for worn-out ball joints. [/QUOTE]
5 Series
