viewfinder;317502 said:Wonder if it works from the passenger side of the door. My driver side key slot cannot turn at all.
I presume this must be documented in the owners manual which people hardly read.
535i;317413 said:works the same if your car comes with a sunroof .
XXX;317610 said:eh! u also got this problem , is this common?
wanted to try the above but also same problem, cannot turn at all...
XXX;420385 said:bro thnxxx for the update......tmw i will spray 1 whole can of wd40 into the key hole or is KY better? normally for holes, KY is suppose to work better dunno if it will work for keyholes though....??
XXX;420562 said:ouuuuchh!!!!
