5 Series
E34 Rear Suspension Bushings
<blockquote data-quote="ehoe" data-source="post: 308" data-attributes="member: 141"><p>Anyone had their rear suspension bushings replaced/renewed?. I was told that worn down bushings in the rear suspension (axel carrier bush & trailing arm bush) can lead to a bumpier/noisier ride and also more pronounced negative camber. True?The replacement of the bushings is not expensive but the job is labour intensive as the entire rear axel & driveshaft needs to be removed to get access to the bushings. Anyone has had theirs replaced or renewed?. How long did it take and any difference in ride quality and camber settings with the new bushes?.</p></blockquote><p></p>
[QUOTE="ehoe, post: 308, member: 141"] Anyone had their rear suspension bushings replaced/renewed?. I was told that worn down bushings in the rear suspension (axel carrier bush & trailing arm bush) can lead to a bumpier/noisier ride and also more pronounced negative camber. True?The replacement of the bushings is not expensive but the job is labour intensive as the entire rear axel & driveshaft needs to be removed to get access to the bushings. Anyone has had theirs replaced or renewed?. How long did it take and any difference in ride quality and camber settings with the new bushes?. [/QUOTE]
5 Series
