ehoe
- Dec 8, 2004
- 308
My E34 ignition key is stuck!. The key can only be turned just slightly enough to release the steering lock then can go no further. So I can't even crank the engine to start it. Somehow something is causing it to be stuck/jammed mid way thru the key turning circle. Anyone has had this problem before? if so what was the problem and how to resolve?I had to dismantle the whole steering cover and remove the ignition starter which is attached to the key lock mechanism to start the car manually using a screwdriver. Help!.
