Hi, just got my E28. It has a M 30 engine. 3.5 auto
Just a few issues to sort out, so I hope those experienced sifu sifu here can give some clues as to where to start.
First order of business
On cold start, eg mornings, car idles cycles up and down between 800rpm to about 1200rpm. This goes away when engine is warmed up.
if the car is properly tuned then it's prob your cold injector control or idle stablizer valve (about 150 used)
When in D and footbrake engaged, engine will rock like a hi-cammed V8 but RPM is a steady 800 rpms.
prob your engine & / or transmission mounts - dont worry they are cheap.. about 50ea - there are 3.. but normally its the one on the "hot exhaust side" that goes first..
Second, I've got a 4 speed tranny, no idea what model. Kickdown at low speed sends a small jolt to the rear differentials. Normal for an 80s tranny?
should be minimal.. you either have play in your prop-shaft , drive-shaft or tranny is shot.... either will nto be cheap :9 - sorry
Also, tranny vibrates for a second or 2 while acclerating from standstill.
sorry.... prob tranny... you can get it repaired for typicallyr a few K , or get a good used one for about 1.5-2K.. a good one should last a long time.. suggest you try flushing & changing tranny oil,,, small chance it will help - if not keep oil for you new tranny so no $ are wasted :rock:
Happens everytime. It feels very much like a lose pinion gear bearing!
could be but typically the selectors, clutch plate wear out one an auto long before the pinon bearing..
Err, lastly, what tire pressure to use ah? Got 16 inch tires on BBS rims.
I think it was about 30-32 all around.. car tends to overstear at limit so you may want to try aabout 1-3 psi HIGHER in the front.. ie front about 33-31.. back about 31-28.
trim to your personal taste in comfort, road feel, balance etc.
Ok that's all for now. TIA.
