Mun
- Aug 28, 2009
- 178
- 18
My 325 had registered the following fault on the I-drive monitor1. Driving stability : Brake and drive control systems failure. Reduced braking and driving stability. Avoid hard braking.2. DBC Failure : No DBC assistance while emergency braking. Drive moderately.3. Start Assistant inactive. Caution, Car can roll back!!It has been checked by Ingress and Rishi reported that the ABS pump is faulty. Need to order from Germany.I'll give it a month. Asked whether this is common, and the answer was common to 325. He's applying replacement under warranty.Since this is "common", has anyone experienced it?And yes, cruise control does not work while this is at fault , as I discovered on my way to Ipoh.http://www.bmwclubmalaysia.com/forums/album.php?albumid=247&pictureid=1132http://www.bmwclubmalaysia.com/forums/album.php?albumid=247&pictureid=1131http://www.bmwclubmalaysia.com/forums/album.php?albumid=247&pictureid=1130http://www.bmwclubmalaysia.com/forums/album.php?albumid=247&pictureid=1128http://www.bmwclubmalaysia.com/forums/album.php?albumid=247&pictureid=1129
