3 Series
E90, E91, E92, E93
Door unlock problem
<blockquote data-quote="alxy" data-source="post: 31181" data-attributes="member: 2947"><p>Bros, today when unlocking my car, all locks were ok except for rear passenger side door. It stayed locked. I could only open it manually via the door handle on the inside. But when car starts off, then it locks as per the other locks. Even using the remote after I have manually opened it, it can lock back like normal. Just cannot unlock only (even if use the door unlock button near middle A/C vent).Read few other forums, say might be fuses. But I checked fuses 2, 19, 56, 57 and 63. All are OK. Well, except I don't have fuse 19 (is this normal???). Am I checking the right fuses? What else could it be? Door actuator? Anyone else face this problem? How much $$$$ to fix?Thanks!</p></blockquote><p></p>
[QUOTE="alxy, post: 31181, member: 2947"] Bros, today when unlocking my car, all locks were ok except for rear passenger side door. It stayed locked. I could only open it manually via the door handle on the inside. But when car starts off, then it locks as per the other locks. Even using the remote after I have manually opened it, it can lock back like normal. Just cannot unlock only (even if use the door unlock button near middle A/C vent).Read few other forums, say might be fuses. But I checked fuses 2, 19, 56, 57 and 63. All are OK. Well, except I don't have fuse 19 (is this normal???). Am I checking the right fuses? What else could it be? Door actuator? Anyone else face this problem? How much $$$$ to fix?Thanks! [/QUOTE]
3 Series
E90, E91, E92, E93
Door unlock problem
