DIY - Melted Plastic Trim For Speedometer BMW e39
uncle aziz
The problem with this unit is melted paintwork applied on the plastic part .Cars left parking under direct sunlight or older cars (more than 6 years) will have this symptom.Scratches can be easily developed even with soft cloth used during the cleaning of dashboard with ugly marks (including finger prints) left on the melted trim surface.DIY : How To Remove melted paintwork from plastic trim 1. To remove the part - must use special screw driver(for BMW/continental cars) to loose 3 screws on top portion and 2 screws under the wood panel. U need to peel off the wood panel from the dashboard first .2. Disconnect all wire connections ( 3 points) before removing the whole unit from the dashboard. 3. Use sharp plastic knife ( cake knife ) to remove all melted paint from plastic trim. Avoid using sharp metal objects such as knife to prevent scratches on it surface.4. Apply heavy duty cleaning liquid (non-corrosive) on the surface and wipe with cloth to clean the whole part till the sticky paint residue completely wipe out. 5. Ready for installation.
