Damn... How Much This Time U Will Cost Me My Dear
zamtresco
After servicing my car last week, the fella chack my car, then these things appeared :-item25 Output stage of oxygen-sensor heater sensor24 Operation of front right outlet valve faulty33 Operation of rear left inlet or rear axle inlet valve faulty18 Operation of front l;eft outlet valve faultyThe mech told me that approximately max will be RM 1.5K to get those faulty repaired but it depends on the spare part needed to be change.... Reasonable price ke? anybody got experience with such kind of faulty?
item
Zam, these could be old alarm.. Ask to reset all the alarm and take your car for a ride... and then check the alarm with modic again.. it the alarm still exist after the test drive then ouch.. some of this alarm could be register if you have disconnected the battery, this is quite true when you have a japnese spec car..
good luck
Jarance... did that but then.............................
IT STILL THERE!!!
item
Hmm, I wanted to help but couldn't decipher which DME these fault codes your mechanic were referreing to? Are they for DME 3.3.1 or DME MS40.x or DME MS41.x. The same fault code appear in each of these DME diagnostic but they mean different things.
Look like you should check on the O2 sensors 1st. Again the price of O2 sensor varied between M50 and M52 engine.
The rest might required to open up the valve cover. Just my initial though on your fault code descriptions.
