coupe similarity with sedan
ABCowner
Hi all,Contemplating on a 328Ci and understood the following from various sources. Appreciate if any Ci owners can confirm; 1) body parts are totally different from sedan 2) engine part is basically the same with other 2.8litre of the era. 3) suspension are the same as sedanBased on the above, I conclude the maintance of a sport coupe is basically the same as say 318i sedan. Am I wrong?
OK - probably not the engine dept. Is the suspension the same? The lower arm, steering rack arm or the shocks the same?
you can checkout the part level difference in realoem.com
to what i have seen, there is considerable amount of changes.
