BMW Tech and Performance
Engine Tech
BVO ECU Remapping for e46 / e39 / e90 / e60 / z4 / e63 / x5
<blockquote data-quote="Shahrezan" data-source="post: 613763" data-attributes="member: 24268"><p>[ATTACH]25128[/ATTACH][ATTACH]25129[/ATTACH]</p><p></p><p>Comment from Mr Bernard:</p><p></p><p>As from the dyno result , we can see a gain of 10whp(7%increase from Standard ), and 25Nm (kg-m2.57 to Nn multiply by 9.8) of torque . The torque graph in the dyno show good improvement at 3000rpm to 5750rpm. As at 3750RPM it has again of 15whp/20Nm of torque, 4750RPM gain was 15whp/ 25Nm , 5750Rpm gain shows 10whp/15nm of torque .As we can see the horse power starts to tapped at 5500rpm onwards which the car is still running on stock standard exhaust and standard filter. Good improvement for a car that has done 188,000km in mileage. I have introduce 3 map on this car which this is the best result of all .Good drivability and smooth in gear change as well after test driving . Any further result improvement ,that has to be done on the dyno to obtain the optimal results which will cost RM$250 an hour.I would like to take this opportunity to thanks all those who have supported me for the past years and done my best to achieve optimal results on their cars.</p><p></p><p>Hi guys,</p><p></p><p>Sori for the late update on the result. Well i guess the above graph has explain on the power gain after the remap session. Thanks to Bernard n all participants.</p></blockquote><p></p>
[QUOTE="Shahrezan, post: 613763, member: 24268"] [ATTACH=CONFIG]25128[/ATTACH][ATTACH=CONFIG]25129[/ATTACH] Comment from Mr Bernard: As from the dyno result , we can see a gain of 10whp(7%increase from Standard ), and 25Nm (kg-m2.57 to Nn multiply by 9.8) of torque . The torque graph in the dyno show good improvement at 3000rpm to 5750rpm. As at 3750RPM it has again of 15whp/20Nm of torque, 4750RPM gain was 15whp/ 25Nm , 5750Rpm gain shows 10whp/15nm of torque .As we can see the horse power starts to tapped at 5500rpm onwards which the car is still running on stock standard exhaust and standard filter. Good improvement for a car that has done 188,000km in mileage. I have introduce 3 map on this car which this is the best result of all .Good drivability and smooth in gear change as well after test driving . Any further result improvement ,that has to be done on the dyno to obtain the optimal results which will cost RM$250 an hour.I would like to take this opportunity to thanks all those who have supported me for the past years and done my best to achieve optimal results on their cars. Hi guys, Sori for the late update on the result. Well i guess the above graph has explain on the power gain after the remap session. Thanks to Bernard n all participants. [/QUOTE]
Engine Tech
