Hi all,I noticed that the most common brake upgrade for the 318 is to swap the standard set up(solid) to the 328 (ventilated). Just a thought, but can a brembo brake set up (say from an DC5 Integra Type R, Lancer Evo, or Nissan 350Z) be installed as well? It's a Brembo brake set after all... Or would it require too much fabrication that it's just not worth it? It's just a thought. Seeing that how used brembo brake sets are readily availible from the chop shops, it's definitely the cheaper alternative to buying new Brembo sets.I know that most forummers here are purists, however I'm just trying to explore this idea from a practical point of view. Hope you guys can bear with me. Thanks!
