5 Series
E28
BMW e28 520i wont start????
<blockquote data-quote="blackbeast" data-source="post: 581753" data-attributes="member: 21276"><p>Hi All,</p><p></p><p>There are 3 main possibilities if the car can't rev up...</p><p></p><p>1) Fuel delivery system : i) Fuel pump ii) Fuel pump relay</p><p>2) Ignition system : i) Spark plug ii) Plug cable iii) Distributor cap iv) Ignition coil </p><p>3) Engine management/Protection system : i) Computer box ii) Engine cut-off sensor</p><p></p><p>Make sure your car battery has enough power (CCA) as it drives the fuel pump and the ignition spark.</p><p></p><p>Happy DIY</p><p></p><p>Blackbeast</p></blockquote><p></p>
[QUOTE="blackbeast, post: 581753, member: 21276"] Hi All, There are 3 main possibilities if the car can't rev up... 1) Fuel delivery system : i) Fuel pump ii) Fuel pump relay 2) Ignition system : i) Spark plug ii) Plug cable iii) Distributor cap iv) Ignition coil 3) Engine management/Protection system : i) Computer box ii) Engine cut-off sensor Make sure your car battery has enough power (CCA) as it drives the fuel pump and the ignition spark. Happy DIY Blackbeast [/QUOTE]
5 Series
E28
