Bad radio reception and upper arm bush cost?
TCNG
Hi there,i just put on a new cd player for my car last weekend. thought that the original cassette player might have worn out that always having bad reception on radio but after putting a new one the problem seems remain. i cant seems to find any antenna in this car. is it a build in antenna? Any thing i can do to get better reception?by the way, any idea how much it cost to change the front upper arm bush? it start to warn out.on last question. what is the fuel consumption like for this e34 24v in highway? my is like 35 litre for 250km. it is normal?
The E34 antenna unit is located at the left rear passenger pillar. Where the reading lights are. Remove this panel and you will see the unit. It uses the demister as the "antenna"
Google for "FZV" antenna or diversity antenna.
There is a possibility that the amplifier which is located in the C-pillar could be faulty or have loose connection.
BTW, do you have any problem with your remote key.
hi all,
Thanks for the good tips. i had install a Mamba car alarm and is doing fine. Is fine to use the key lock too. can the antenna be replace?
regards,
TC
TCNG;543895 said:
hi all,
regards,
TC
Is your demister working?
If the demister is working fine, then to replace the antenna you would also be replacing the demister.
The demister and antenna are integrated together. Better to check the amplifier or the diversity antenna/module. It could be a loose connection only.
TCNG;543827 said:
Hi there,
As no one's answered the last question, I'd say it's not normal. What is your engine capacity? I drive a 520i, can easily get 10km per liter and that's with driving between 140-160km/h. Even if yours is a 525 it should be better than what you're getting. Unless you have a JZ beast under your hood...then it's normal. :wink:
hi Hammer278, thanks for your update. mine is 525, i am not sure if this because of the spark plug that have worn out. i just got it change last week. i will try to test it out again when i go back to ipoh in mid of Aug. my engine is an original without any modify.
if it still the same fuel consumption after the spark plug change, what other factor can cause high fuel consumption?i am not a heavy foot. usually on highway i cruise around 100 to 120 km/hr.
can we change the frequency for e46 radio jpan to local frequency w/o change the radio
You fuel economy is off by 30-40% which is very bad. Your air flow meter is not functioning correctly, or your o2 sensor, or your air filter is dirty, or your throttle body and intake manifold area is too caked by carbon, or any combination of all of these. These are the top candidates for poor fuel consumption. Also, check your bellows....this is the air hose that connects your afm to the throttle body. There could be cracks there underneath that you can't notice.
It would be a good idea to get your car scanned by a computer and have any stored error codes read and then deleted. That can zero in on things very very fast. My money is on the O2 sensor and the afm.
Oh btw check your tyre pressures when they are cold (i.e. in the morning, drive to petrol station slowly). You should be running 225kpa front and 240 kpa for the rear. If you have any odd readings, you may have a small puncture - get that sorted out immediately.
Other possibilities for poor fuel consumption would be vacuum leaks (usually detectable by a poor idle when the car is stationary, caused by cracked air hoses), or a dirty fuel system. Change your fuel filter if you haven't done so recently, run fuel injector cleaner through your system (put in 4 litres of diesel on an empty tank and then move to the petrol pump and fill up to full with petrol, the two will mix, no problems for the engine, the diesel will work as a fuel system/injector cleaner). If necessary, you may need to take out your fuel injectors and have them ultrasonically cleaned and backflushed to remove dirt, This is pretty rare, but anyway its a good thing to do at least once every 5 years anyway.
You may have other problems (slight or major) which can only be observed by a trained eye, so tell your mechanic about your poor fuel consumption. Good luck and let us know how it goes. And I would suggest that you get this looked at today, you are wasting tons of money on petrol so every day you don't fix this you're literally losing money.
