3 Series
E36
Auxiliary Fan Switching
<blockquote data-quote="Vincent Hor" data-source="post: 237037" data-attributes="member: 1221"><p>The aux fan has two speeds. It runs on 1st speed most of the time. When tempreture reaches a certain higher level, the thermo switch (located behind the grille colse to the aux fan) will activate the 2nd speed. </p><p> </p><p>Most competent mechanic and a/cond specialist can trace and rectify this problem.</p></blockquote><p></p>
[QUOTE="Vincent Hor, post: 237037, member: 1221"] The aux fan has two speeds. It runs on 1st speed most of the time. When tempreture reaches a certain higher level, the thermo switch (located behind the grille colse to the aux fan) will activate the 2nd speed. Most competent mechanic and a/cond specialist can trace and rectify this problem. [/QUOTE]
3 Series
E36
