A.C and aircond fan not working..need help
mrifaee
hai forumer..my e34 A.C and aircond fan seems not working..only blower is working. aircon relay is fine. Any idea from otai's out there how to solve this poblem. thanks
MIght want to check the compressor and AC fan motor. I had my motor quit once, it's a job to replace...2-3 hour job. Second hand fan + motor available for around rm300. Brand new around rm600-700.
thanks hammer..for your info my problem start when i park my car for 3 days and when i'm start the car there's some stinky smell in the car.at first my radio is not working well. when i started my aircond only blower is working. i just change my old battery before the case happend.
Was your car was parked in cold/rainy area? The stinky smell might just be the clogged aircond vents. And it could be your new battery might have shortcircuited the AC fan. Try the fusebox first (left hand side in engine bay), replace the fuse for AC fan, if that doesn't work might have to dig out some cash for a new fan mate.
:) Could only let you know tonight...my car's parked at home and I commute to work. Can't now, hopefully one of the sifus here could give you a reply soonest.
the fuse box lid inside will have the name - 'aux-fan' and the fuse numbering with the fuse rating..
thank bro..will chek this evening..still open with any idea from forumer thanks..
mrifaee;605675 said:
found the culprit...my aircond control unit blown already...anyone has it?
your car 12valves or 24valves? what you mean by a/c control unit? the whole big unit inside the dashboard or the front panel control buttons on the dashboard? I have items from 12valves model.
wow is this some kind of a bug... i'm having the same problem too... will send it to the mech later... as for mine, im pretty sure tht it is the fuse, as i didn't start my car for a week, due to holiday. then after jump starting the car, the thing that happened to you, happened to me too.. so im pretty sure AC fuse is the problem.
bro morpheus..mine 12v..the thing is in the dashboard..blown already..if u have do u willing to sell it to me?
Bro Iylia H:yea the same bro..but mine the ACCU blown..better chek that also
