ICEMAN 68
Founding Member
- Dec 4, 2004
- 8,055
hey all just wondering if anyone had the similar issue as mine .... Problem : knocking sound at front driver right hand side at 2K RPM ( when slammed hard down from low rpm to top AND when climbing up hill gradually )Tendency : Always happen ( cold and hot day )engine : slow 6 potter items changed : before even the vanos seals being replaced the noise had been there .. 1) so upon changing the vanos seal together with the plugs and top gasket, the knocking is still there 2) cleaned all the MAF / TB and ICV , knocking is still there 3) Fuel filter , knocking still there Lastly suspected due to a weakening fuel pump hence not enough pressure ..changed that too and problem is still there anyone could shed some light to this gremilin ?also tried running on 97 for 2 weeks or so and the knocking is still there
