3 Series
E90, E91, E92, E93
320I E90 Gear box oil change
<blockquote data-quote="Tiaraz Residence" data-source="post: 743804" data-attributes="member: 49020"><p>Change atf around 6L with filter. </p><p>If ZF gb use plastic pan - must replace pan with filter</p><p>If GM gb use black metal pan - can replace filter only</p><p></p><p>Normally before 100k km. That is define by bmw, lifetime =100k km</p></blockquote><p></p>
[QUOTE="Tiaraz Residence, post: 743804, member: 49020"] Change atf around 6L with filter. If ZF gb use plastic pan - must replace pan with filter If GM gb use black metal pan - can replace filter only Normally before 100k km. That is define by bmw, lifetime =100k km [/QUOTE]
3 Series
E90, E91, E92, E93
