BMW Tech and Performance
Engine Tech
2005 e60 service indicator reset
<blockquote data-quote="Rick1" data-source="post: 736414" data-attributes="member: 43572"><p>Just as an update. I spent numerous hours on the internet last night and found the following. The exhaust and country (?) inspection tags are re-set using the i-drive whilst the micro filter alert is re-set using the odometer reset method. That explains why when I tried to re-set through the odometer re-set method the dates would not change. I have now resolved the service indicator.</p><p></p><p>Many thanks to Moots for his advice.</p></blockquote><p></p>
[QUOTE="Rick1, post: 736414, member: 43572"] Just as an update. I spent numerous hours on the internet last night and found the following. The exhaust and country (?) inspection tags are re-set using the i-drive whilst the micro filter alert is re-set using the odometer reset method. That explains why when I tried to re-set through the odometer re-set method the dates would not change. I have now resolved the service indicator. Many thanks to Moots for his advice. [/QUOTE]
Engine Tech
