5 Series
E34
1989 E34 M20B20 - Radiator Leak
<blockquote data-quote="lance" data-source="post: 313966" data-attributes="member: 13039"><p>Hey guys,</p><p></p><p>The radiator has been replaced. He has removed and checked the Thermostat, Water pump, hoses and belting. All seem to be ok.</p><p></p><p>Quick question - how do we know if the cooling system is running ok? As usual, the top hose is hot and bottom is colder - this is normal throughout the operation of the engine, right?</p><p>How about the temperature gauge - at idling, it should be about half? If I run the engine idle for 30 mins and check the hoses and temp. gauge - what should be the feeling/reading? Same? </p><p></p><p>Another question, is it normal for the radiator cap to rattle during the above testing using pipe water?</p><p></p><p>Thanx guys.</p></blockquote><p></p>
[QUOTE="lance, post: 313966, member: 13039"] Hey guys, The radiator has been replaced. He has removed and checked the Thermostat, Water pump, hoses and belting. All seem to be ok. Quick question - how do we know if the cooling system is running ok? As usual, the top hose is hot and bottom is colder - this is normal throughout the operation of the engine, right? How about the temperature gauge - at idling, it should be about half? If I run the engine idle for 30 mins and check the hoses and temp. gauge - what should be the feeling/reading? Same? Another question, is it normal for the radiator cap to rattle during the above testing using pipe water? Thanx guys. [/QUOTE]
5 Series
E34
