10mm H&R spacer
Yutayut
Hi allI want to know how much cost for e39 10mm H&R wheel spacer and where to get it?Do I need to change the bolt together and how much it cost?Need advice from the expert...Thank you.
Hi bro you can check with EuroTuner. Kelvin has them from H&R. Cost includes spacer + screws. Pricing just call him. He is a under classified section.
your ride is running on how many inch rim bro and what bout the offset?
For 18", i would rec go for 15mm (10mm doesnt make any dif.), u have enuf space for that E39.
I have two set of rims at the moment. Still not decided which one to use.
1) Front Wheel Size: 17" x 8" 20mm offset (IS20)
Rear Wheel Size: 17" x 9" 26mm offset (IS26)
2) Front Wheel Size: 18" x 8" 20mm offset (IS20)
Rear Wheel Size: 18" x 9" 24mm offset (IS24)
So any advice on that info. Do I need to install the spacer on front and back?
Thanks.
Tts plenty of space for ET20 rim (front). 10mm spacer will not give any extra conelip to hold up the rim.
I suggest you buy 15mm 1 pair for frnt and at the same time u can use it and try out for rear.
